tbarile
- Dec 21, 2010
I have an 05 RX1 and had to have an arm in the skid welded and now can’t get it back in!! Interestingly I’ve read numerous threads that talk about 3 sets of bolts that hold the skid in but I only removed 2 sets to pull it out. I can’t get the front arms to push up high enough to get the bolt in. I’ve spent hours and can’t get within 2” of the hole.
Please help.
Please help.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
remove the rear bolt to transfer rod so it is not hooked to rear arm. This will allow you to easily line things with tunnel.
tbarile
- Dec 21, 2010
Thank you. I had the front boot removed. Made it a lot easier with the rear removed.
Now, how do I get the rear bolts to line up? I have 2 ratchet straps around the spring trying to compress but I’m still off by 1/2” and I can’t compress the spring any more.
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
After attaching the front arm to tunnel bolts& with transfer rod unhooked you should be able to lower the rear of sled down & then have someone push down on the bumper to help line up the rear bolts, use a lineup punch to make sure the holes are aligned properly so you dont strip the threads on the bolts or the shaft, shouldn’t need any kind of straps on your shockThank you. I had the front boot removed. Made it a lot easier with the rear removed.
tbarile
- Dec 21, 2010
I hooked the transfer rod back together prior to trying the rear bolts. I’ll disconnect and give that a try. Thank you
that is the mono shock rx1. you would be better off looking for how to get skid re installed on an apex. i do not have any experiance with the mono shock skid myself.
Brotherdan
- Sep 8, 2017
- Belmont,maine
Yes 05 is the same as an apex& the same as mine which has been converted to a 13 vector ltx skid sounds like he got it all back togetherthat is the mono shock rx1. you would be better off looking for how to get skid re installed on an apex. i do not have any experiance with the mono shock skid myself.
