Getting Closer On A RTX SE But Still Not THERE!!
Center shock isn't as bad as the rear shock in my opinion, cannondale should be able to get u hooked up with a great valving setup, I believe he has been going thru carver. I had monster performance here in NY do both my rear shocks and it was the best $160-$170 I spent
Ian from monster i remember from doo talk...same guy? How long is the turn around time to get them done?
Yupp that's him, he's got a great setup for the viper. Just talked to him late last week about a different sled and he basically made it sound like 2-3 day turn around once he gets the shocks, so figure in shipping times your prolly looking at roughly a week total
how do i get ahold of Ian again... its been along time since doo-talk days..
I have a cat sno pro XF 7000 LTD with the 137 inch track what I found was the suspension was acting like a see saw right now I have the floats set at 75 psi I took the spring of the front skid shock and replaced it with a 190 lb straight rate spring and pulled up the limiter strap 1 hole that has stopped the darting inconsistent ski pressure and the high speed drifting you described Right now there is a little more ski pressure than I like but this is a starting point and a good baseline.
