BryanK410
Hey I was wondering if anyone knew a good apex riser?
2" higher be perfect.
I would go to http://www.lakeffectsnow.com/
BryanK410
Thanks, think I'll go with the 10" polished and black.
He makes some nice stuff.
BryanK410
Ordered now. Hopefully I wont have to mess with my cables if there is enough slack going from the stock 8" to 10".
The only problem I had raising mine 2" was the throttle cable but I re routed it underneath and have had no issues.Ordered now. Hopefully I wont have to mess with my cables if there is enough slack going from the stock 8" to 10".
BryanK410
Actually had to order the 3" pivot adapter with 7" risers. He was great to deal with and messaged me about what I needed. can't wait to get them.
BryanK410
Cable is just a bit too tight? Where to find some extra length re routing it or do I need a longer cable and if so where would I get that
slowride06er
Did you figure out the cables?
Berg570
I could not find any slack. I raised mine up just an inch, and that's all I could get. It was the brake line that ran out.
Rotating the bars slightly forward helped with the feel, somewhat.
slowride06er
How do you route underneath?The only problem I had raising mine 2" was the throttle cable but I re routed it underneath and have had no issues.
If I remember correctly the cable goes over the bars then into the throttle block. I routed it under the bars into the throttle block.
