I added an 2011 Apex to my Fleet. It's in perfect condition
I did find the hand warmers don't work, the icon showed on the dash but the Bars do not show up. Does this mean that both sides are burned out. I checked the fuses in that small block above the chain case. What am I missing?
Also this sled has 2 sets of Low Snow wheels on it.
It looks like the bearings are worn. I can grease them and make them last another season . Where is a good source for these bearings. I believe they are 6004
I have had a few 11’s with bad grips. I think yamaha had bad batch on the line. I would ohm test them. Bearings are 6004. Best to replace. Those bearings see high rpm since small diameter and fail much faster. I sell them for $6
ps...i almost bought that sled. Was too busy in shop to make it out. Lucky for you!
