GPS Charging
Rdhobs99
Michigan
20212 Yamaha Nytro XTX
I am looking for a cord with a mini USB plug that I can plug into my heated shield plug. I want to charge my gps from the heated shield connection.
SMART SUPPLY Plug&Play Power Port
Ski Doo Install Smart Supply comes with 1 RCA Cover & 1 USB Cover 2 RCA outlets & 2 USB Outlets to power your devices Tough, Handles the elements
The RoczToyz.com SMART SUPPLY is a super quick, easy, Plug & Play multiple power outlet for your ride!
SMART SUPPLY has TWO 1 Amp USB outlets to charge/run anything with a USB cord.
You can easily charge/run your Phone, I-Pod, GPS, MP3 player, ANYTHING USB powered, as you ride!
It is fully Garmin & I-device(Apple) compatible!
(Garmin & I-Phone require the USB Port and charge cord to be compatible, Port is compatible, use your compatible charge cord)
Will charge all devices in high current/fast charge mode if the device calls for it.
This means you can easily use the GPS function on your phone AND charge the battery at the same time!
The SMART SUPPLY also has TWO 2 Amp 12v DC RCA outlets that provide easy, reliable power for heated shields, gloves, etc.
All outlets provide power that keeps working & won't vibrate out as you ride.
Install is as quick and easy as:
1) Simply plugging into your stock harness. (On most units)
2) Peel & stick with the included velcro!
Provides easy, clean, fast power for any of your devices with one simple connection!
SPECIFICATIONS:
Super Efficient Low Current draw: 10 mA (.01 A) (+ Current output to devices.)
Voltage Input: 6-12V AC or DC (Works on ANY 6-12v system, 2 OR 4-stroke)
Constant Output Current Max:
USB 1 Amp x 2, or 2 Amp x 1 (2 Amps total USB current out)
USB Outlets include one silicone USB plug to help protect un-used outlet.
RCA Outputs: 2 Amps constant per outlet x 2 (4 Amps constant total RCA outlets)
(5 Amp peak per RCA outlet)
(RCA output voltage is dependent on Input voltage, with 12v in (AC or DC) you will have clean 12v AC or DC out.)
All USB outputs are Input Voltage Surge Protected:
If your machine's voltage regulator should fail, the SMART SUPPLY will help protect your sensitive electronics.
The SMART SUPPLY also protects your USB powered electronics from normal electrical surges.
Plug & Play Available for:
All 4-stroke Yamaha Snowmobiles: Apex/Attak, SRXviper, SVRviper, SRviper, Phaser, Nytro, Sidewinder etc. P&P
All 4-stroke Yamaha Quads: Grizzly etc. P&P
All Yamaha Side by Sides: YXR1000R etc. P&P
All 2 Stroke Viper, SRX and like models P&P
All Ski-Doo with cigarette Lighter outlet. P&P
All Arctic Cat 4-stroke Pro-cross models. P&P
All Arctic Cat 2-stroke models P&P
All Polaris with Cigarette lighter outlet or accessory 12v DC plug P&P
Most any other machine with AC or DC system.
Universal Unit comes with extra connector, may need to connect 2 wires to machine.
DIMENSIONS:
2x3x1" DxWxH (50x75x25mm)
i use this to run my gps and charge my cell phone while riding.
link to his site
http://yamaheater.com/Products.php
