- Jan 16, 2020
- Hamilton, On
- https://mainwaysolutions.ca
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
- ramody44@yahoo.com
When will the rear extension arm bushings be back in stock?
Birdmansrx
- Oct 5, 2019
- Northern N.H.
- srx
I would love to have a kit to tighten up my steering in my 2020 SRX. Have you any plans to make something for that ?
Years ago I used to buy front end bushing kits for trailing arm yamaha's from a guy in RI, sno -tek I think. Great products but I think that business is gone ?
- Jan 16, 2020
- Hamilton, On
I'm thinking the middle of April, or Sooner
- Jan 16, 2020
- Hamilton, On
The MAK01 kit will fit your sled.....
2020 YAMAHA SIDEWINDER SRX LE
Birdmansrx
- Oct 5, 2019
- Northern N.H.
- srx
Those look like a-arm bushings . I am looking for a bell crank fix
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
Great, want both kitsI'm thinking the middle of April, or Sooner
- Jan 16, 2020
- Hamilton, On
I'll have a look at one with about 4000 km....wont be until summer till i get around to it.
ksiesel
- Mar 25, 2016
- Columbus, Indiana
- 2015 Viper RTX-DX with QS3’s, winder jackshaft, RR front arm shaft, 4 wheel kit, and many more upgrades
- Columbus, Indiana
Have a look at this thread starting at post #60. There is a LOT of detailed info about what I found as I dove into steering play on my sled and how I addressed it with some custom machined parts.
https://ty4stroke.com/threads/cross-shaft-damage-and-repair-info-and-pics.145856/page-5
- Jan 16, 2020
- Hamilton, On
Definite need of some attention. Just like every other sled on the market they build this sled with lots of clearance.
Ski-doo, Cat, Polaris, They are all built with huge clearances and they just pound themselves apart.
I'll definitely be looking at this as i think i can address this problem and come up with an affordable Solution.....
Birdmansrx
- Oct 5, 2019
- Northern N.H.
- srx
Thank you
- Jan 16, 2020
- Hamilton, On
Well i have been knees deep into this Cat Front End. Wow I couldn't believe how much play was in the Bell Crank. This sled has 6000 KM on it and the bushings didn't look that bad just oversized.
Too much clearance. I managed to make a few bushings for this project and it worked out well. Zero slop!! My buddy will be very happy.
I hope to have a few kits available first of next week. if your interested let me know.. I don't have a $$$ yet
here's a few Pics
I used a puller threaded rod from my Ski-doo Front arm kit, Pull them in till they bottom
The Bell Crank shaft was in great shape. The only thing I did was remove the paint from the Post with scotch-bright pad, took a few minutes. I was tempted to doo it on the lathe till I came to my senses. don't try it!!!
Cleaned up very easy. I filed some high spots at the end of the tube. With better fitting bushings the tube fit perfect. Use red loc-tite on the 6mm nut and torque to 10 ft lbs Max..
That driver in the pic will remove the bottom plastic bushing after you punch out the upper bushing.. Use it to install the new bushings as well
Val
here's a few Pics
Val
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Val put me down for a kit, mine has a lot of up and down play which I don’t like.
- Jan 16, 2020
- Hamilton, On
Well this kit definitely takes all the slop out of the Steering Crank. Your going to love it!!
How did you like the other kits you purchased. I think you purchased the MYK01 Control arm kit and the MYK05 rear extension arm kits.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
I was impressed with both kits, front a arm kit (MYK01) went on with percision, awesome quality to say the least, the rear extension arm kit (MYK05) was also a needed add on as my bushings were already showing wear.
Keep up the great products and I’m looking for to install your bell crank bushing to eliminate the slop in my steering
.Similar threads
