Grizzly clutch spring??
raxxor
What color spring comes with a clutch kit with oversized tires? What will i gain by just installing this spring? I already have 450 kodiak weights. Will this spring stall my engagement? Will i lose top end? Where can i buy it? Thanks
You will gain more by putting a 1/2 shim under your secondary spring. Top speed, adding different wet springs will change your engagement and let it rev more.
WHATS THIS ABOUT PUTTING A 1/2INCH SHIM IN THE SECCONDARY SPRING?
WHAT IS A GOOD FIX FOR LOW END,,,, IM THINKING LIGHTER WET CLUTCH SPRINGS AND HEAVYER WEIGHTS IN THE PRIMARY
sorry messed that up heavy wet springs to get rpm up and light weights to keep the clutch from closing keeping the ratio low
