Kkurz
- Nov 1, 2016
- Peterborough On.
- 2014 XF7000 Sno-Pro Limited
(Yamaha powered)
So, I was approached by a cross-country ski club the other day about grooming their trail. They have a drag made for it and would like me to pull it with my sled. The question is, am I going to burn my drive belt pulling this rig? I'm not allowed to go faster than 15km/h. (9miles/hr). I don't mind helping them out if it isn't harming my sled. I do have access to an RS Vector also which I thought would be more suitable. Thanks for the help guys.
Rich Kay
I would say yes it could be a little rough on the sled.... The belt and clutches for sure.
allyammies
Yes it will that is just barely in and out of engagement of your clutch.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
depends how much weight the drag is?
gitrdun
And what about overheating? Extra weight and low speed is usually not a good combination.
ToddMeister
- Jun 30, 2003
- Bay City, MI
- Yamaha SR Viper LTX LE
- YAHOO
- tmeister73
A VK series sled would be more suitable for this application. You will have overheat/belt issues towing a drag with an RS Vector.
snowfever27
- Jan 7, 2015
- Vermont
- 2015 Arctic Cat XF7000
2009 Yamaha Nytro XTX (sold)
2007 Yamaha Phazer FX (sold)
2005 Ski-Doo MZX 800 Adrenaline (sold)
2003 Arctic Cat F7 EFI (sold)
2007 Yamaha Attack
2009 Polaris 600 Dragon SP
- Vermont
Honestly I would not tow a drag with my XF7000, it’s not designed to tow, maybe it would be fine towing a ski- boose or kids on a sled, but a trail drag all loaded up with snow is a bad idea. I would tell them you would be more than happy to help them find a nice used long track sled, and groom with that sled, and leave the XF out of the equation. There are plenty of used skandics, vk’s, Indy wide tracks, etc out there for an affordable price.
Kkurz
- Nov 1, 2016
- Peterborough On.
(Yamaha powered)
Ya, you guys are all addressing the concerns that I had imagined. I'd like to help them out but it would be better with a sled with a low range gearing.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Or a quad with a track system!
Most CC ski drags are only a foot wide and just put the two grooves for skis in trail. Its not like a Sled Drag. I would give it a try keeping close eye on engine temp and clutch. This is a good opportunity for some good PR for us snowmobilers and I never pass on a chance for that. If you do this. THANK YOU!
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I agree, using low range too.
No way I pull anything that slow with a sled unless you want nice groves on the bottom of the drive clutch. It doesn't even fully engage at that low speed. You'd need to gear as low as you could get in the chaincase to make it feasible without slipping the belt.
I agree the sled isn't made for it but at least a try would go a long way for PR and would not hurt sled if attention to temp and clutch is made. Cripes I pulled a stuck snowmobile trailer out of the snow with my sled and nothing was harmed at all. Never slipped belt at all. Just cant be hesitant at start.I agree, using low range too.
Kkurz
- Nov 1, 2016
- Peterborough On.
(Yamaha powered)
Apparently last year he had some rugby players pull it by hand... I'm thinking about giving it a try. Would it help if I went to a belt with a softer compound? Does this chassis have a fan that will come on at temperature?
Pstn head
Not sure if a softer belt will help reduce if any grooving the cluctch sheeves, probably will. your sled does come with a fan for cooling. It's great that your helping the ski club in your area but like said above keep an eye on your clutch faces and engine temps when grooming.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
It can't be heavier than a snowmobile, so towing it shouldn't be the problem. The problem is if they keep you to that 9mph. Once you get rolling, you need to find that "sweet" spot where the engine & clutches are comfortable. For my Sidewinder towing a 800 E-tec or Rush, it was about 40 mph. Keep in mind that was over 700 pounds with all that track friction. If that drag is just less than a couple hundred pounds & is designed to slide, i don't see a problem.
-use an old belt or put a new one on for riding
-it will be nice deed, because most X-country skiers HATE us, so find a way to get it done
-use the Vector
-use the Vector
