ratman
my guage pod showed flashing yellow light on far left, with flashing gas guage and little flashing gas tank symbols. Luckily we were close to home so we drove there. However, the flaashing stopped.
Performance appeared unaffected
Does anyone know what this could be?
yox185
Uh was it low on gas?
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Are you running low in fuel?
ratman
We had started the trip with 3/4 tank of gas. We used about 1/4 tank.
We had stopped for gas ( premium) to fill up about 5 miles before this flashing
- Nov 1, 2009
- 2009 Phazer RTX
Check to make sure the fuel level sender in plugged in on the gas tank maybe?
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
You may have gotten bad gas then, I think when the gas light flashes that means the ECU is detecting some moderate "Pinging" and pulled some timing to protect the engine. Did you notice any loss in performance?
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
ratman said:my guage pod showed flashing yellow light on far left, with flashing gas guage and little flashing gas tank symbols. Luckily we were close to home so we drove there. However, the flaashing stopped.
Hell with your light coming on at least you were riding!!
But WHERE? (you got no location listed)
ratman
No loss in performance.
However,I heard rumors last year that the gas station had watery gas last year. I will siphon out te gas and put it into the Nuvik. Nuvik will run on anything.
Riding location... Between Witney and Bancroft, Ontario.
Main trails are groomed. Side trails not yet groomed.
With few other sledders to washboard it, the trails were excellent in most places.
We did 150 kms in the last 3 days.
It was just a 600 etec and me... I will post under First ride.
check he connection for the fuel lever sender in the right front corner of the tank
- Nov 1, 2009
- 2009 Phazer RTX
yamahas said:Check to make sure the fuel level sender in plugged in on the gas tank maybe?
Check page 15/16 of your owners manual (at least that is the pages for mine) with regards to the gauge pod.
If you have the gas pump and the orange triangle flashing is a malfunction. Check the connection on the tank.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
You might want to consider doing a diagnostic run and see if there's any hard latched codes.
If you have no codes you can probably write it off as shite fuel!
