legend
I think there is no reason why you cant gut the stock pipe for a aftermarket pipe it is 6 700 dollers candian thats to much for for what you get .But would let some imfo on it . Thank you
170plus
- Jan 14, 2004
- washburn maine
- 2021 polaris assault 850,18 sidewinder ltx,14 nitro xtx,06 apex rtx,
i did my 03 rx1 and it sounded good,i gutted my rtx the same way except i actually cut a section out of the glasspack inserts inside the can,wow sounds awesome,didnt cost a penny ,just a few hrs of my time
**sj**
gutting
you should post some pics of your surgery
Yamahammer485
I agree with sj
Id love to see some pics, hopefully might be getting an Attak and want to do the same.
Dynoray
legend said:I think there is no reason why you cant gut the stock pipe for a aftermarket pipe it is 6 700 dollers candian thats to much for for what you get .But would let some imfo on it . Thank you
We tried that, lost 3HP but did save some weight. We haven't found another pipe that makes as much HP as the stk Apex pipe.
Ray
alaskanbowtie
>>>Dynoray said:legend said:I think there is no reason why you cant gut the stock pipe for a aftermarket pipe it is 6 700 dollers candian thats to much for for what you get .But would let some imfo on it . Thank you
Ray
What about the Excell pipe ? Have you tried it / or the Hauck, what did it loose if you tried it ? (the MPI pipe is the same as the Hauck) if you could answer this question it would help me with some decisions for sure !
170plus
- Jan 14, 2004
- washburn maine
gutted my 03 rx1 and my rtx mufflers,if i lost 3hp it was worth it cause the sound is awesome and it didnt cost a dime,i also machined about 2.5lbs of rotating weight off rtx driveline before i even had it on the snow so i think that made up the 3hp
alaskanbowtie
>>>170plus said:gutted my 03 rx1 and my rtx mufflers,if i lost 3hp it was worth it cause the sound is awesome and it didnt cost a dime,i also machined about 2.5lbs of rotating weight off rtx driveline before i even had it on the snow so i think that made up the 3hp
Can you explain what exactly you machined ? Will this weaken the part......? Sounds interesting !
my yammi vice
I have cut the glass packs out of a spare muffler and put it on my Apex GT. I LOVE the sound. It adds at least 30 mental horsepower.
granto211
Nothing like a mod u hear every time u touch the gas. I cut out both cross over pipes and had it welded shut with stainless steel weld for $50. Sounds awsome, i have a sound clip in the apex section title. My 06 apex rtx projects.
