Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
So we debated b4 the start of the season. Should we or shouldn't we stud the center 3.5"? Possibly hit louvers?
So anyone tearing up the middle? How long are your picks?
Kevin
135 1.325 studs and yes some in the middle
A couple of scratches on the middle protector but I did bottom out pretty good once
69redmach!
- Nov 27, 2016
- Loudon
- 2017 Sidewinder LTX SE
144 1.325" up the middle, no damage anywhere with 670 miles so far. Stock 1.25" track.
buyrite01
4 sleds with 1.450 no marks and fully studded
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Tunnel protectors installed?4 sleds with 1.450 no marks and fully studded
Doc Harley
- Oct 17, 2016
- Here & there
Like hitting a rough run of giant moguls? Or worse?
Kevin
Like a little rough and a fat guy not paying attention
**sj**
The general consensus is 1.325 you are okay to go anywhere..1.450.... Hit and miss... Many no problem some hitting.... Anything over without further modification... Hitting for sure... I've seen some pics of it shredded up good...
With the rumors of how tight Yamaha will be warranty wise... It's concerning for those who care
Doc Harley
- Oct 17, 2016
- Here & there
What's the consensus on 1.375"?
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
That's what I'm running. 144 in the middle. Plenty of traction. Hasn't hit anything. I don't drag race though.
Hammer Down
- Oct 7, 2016
- Loudon, NH
- Sidewinder STX-DX 2017
Apex XTX 2012
1100saber
- Dec 17, 2016
- northern ontario
- 2017 Sidewinder LTX-SE
- AlliedPerformanceShoppe@outlook.com
192 1.575 singles. Ignored the warnings and studded as I would normally do. Not marks yet...but not worried if it does shred that center fin thing...no coolant in it.
yamahaex50
I checked mine today and no issue so far...knock on wood! 144 1.4" extreme max up the middle woody pattern.400 miles
Scottyvodka
Stick with 1.325 on an 11/4 track and don't put studs in the dead center of the track and you'll be fine.
Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
I put 144 up the middle, but avoiding the dead center. Also, avoided sides, as actual bulletin from camoplast recommended. I went with 1.325 and used a combination of doubles and singles. I'm would guess that length would've been fine even on the center, but I wasn't taking any chances.
- 28K
