Smokum
- Jan 31, 2011
- Prairie du Sac WI
- 2011 Apex XTX, 2003 RX-1 MTN
In need of at least 1 new shaft for the GYTR shock rebuild. Looking for the hollow type so I can have rebound control. Cannondale has my shocks, but said none of his sources have shafts for these anymore.
So asking the TY family if anyone knows where to get new ones, or if anyone has 1 used one I could buy.
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
call hygear orMike at Carver Performance
Smokum
- Jan 31, 2011
- Prairie du Sac WI
I will try Hygear. Carver doesn't have anything.
Google also brought up Shock Tec in Canada. I emailed them a number of days ago, but didn't get a reply. Will try calling them too. Anyone dealt with them before?
darv
- Aug 9, 2005
- 08 Apex 40th LTX
you can also go to a machine shop and get one made too. i have done that before.
shock tec have done refresh and re valve work for me before but i always got my own shafts and stuff if they where needed on a shock rebuild.
sgauthier
i would think you should be able to find some of those shocks somewhere. Did you try Barn Of Parts?
Travis has complete shocks but no shafts.i would think you should be able to find some of those shocks somewhere. Did you try Barn Of Parts?
sgauthier
might just be easier to just buy one shock instead of trying to get a shaft made. I'm sure the price wouldn't be that much more anyways. good luck
Yes nobody is going to make these since rebound requires them to be hollow. He really needs two since the one complete shock the shaft is bent. Only matter of time before that breaks too. We were just hoping someone knew of a source.might just be easier to just buy one shock instead of trying to get a shaft made. I'm sure the price wouldn't be that much more anyways. good luck
twyztid
- Feb 14, 2011
- Middleville, MI
- 2017 Sidewinder LTX SE - TD Power Trail, CAI, 3" Super Quiet
2012 RS Vector
2006 Apex GT
- Middleville, MI
No. That one doesn't have rebound. Those I can get new from a bunch of places. Thanks for looking though.
darv
- Aug 9, 2005
- 08 Apex 40th LTX
you can get them made an made out better material get hold Bruce scharder sorry about spelling but Tom from ty may have contact info he did a set of shock for me and had better shafts
made for my ohlins because they where not made and more but cost was not bad like 60-70 per shaft. also try a Canada shock rebuilt company they may have or still can get the parts.
Vectornut
I think all GYTR GT shocks have the calibrator both top and bottom. In the EBAY picture above, have the seller turn the shaft around and the damper knob will show. I believe that shock rod is the correct one for you.
