DennyTuna
- Jan 28, 2017
- Ohio
- 18 Winder LTX 50th
16 SR Viper RTX (red)
02 SX Viper ER (red)
97 SX Vmax 600 (red)
Replacing the hand grips on the 02 Viper (I know its not a 4 stroker). Is there some type of glue or bonding agent I should be using when installing the new grips. I removed the old ones and there was something used just not sure what. Thanks in advance for any advice!
Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
I just use compressed air to take them off and put them back on.
I do the same but there is a grip glue from Yama-Lube. https://www.rockymountainatvmc.com/p/941/35567/Yamalube-Yamabond-7
RobX-1
- Coldwater, OH
I have used hair spray to install them and haven't had any problems with the grip coming loose.
Thats a great idea!! That with a little air would be the trick!!
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
This or spray paint works surprisingly well.
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
I have done the same as well. Hairspray lubricates going on, and sticks once dry. But not to the point that you can't get the grip off again if needed down the road.
Good luck!
use paint all the time on atv and wr grips.
DennyTuna
- Jan 28, 2017
- Ohio
Hair spray sounds like the ticket, spray paint is not a bad option either. Using air is a nice tip too! Thanks for the advice guys.
snowfever27
- Jan 7, 2015
- Vermont
- 2015 Arctic Cat XF7000
2009 Yamaha Nytro XTX (sold)
2007 Yamaha Phazer FX (sold)
2005 Ski-Doo MZX 800 Adrenaline (sold)
2003 Arctic Cat F7 EFI (sold)
2007 Yamaha Attack
2009 Polaris 600 Dragon SP
- Vermont
I used grip tape on my Ski-Doo Rev 800. The stock grips got so hot they spun on the bars and broke the elements. I put new heater elements on and then used this grip tape. It worked much better than I was expecting and was much easier to install than grips. More comfortable too. And it held up for 2,000 miles, then I sold the sled. For $20 you can’t go wrong.
http://www.rsiracing.com/GEL-GRIP-WRAP-GRIPS_p_25.html
