Pabstkiller
- Oct 20, 2021
- Rothschild Wisconsin
- 2006 apex
going to look at an 03 rx1 and the guy says that its a real bitch to start when its cold. any ideas what would cause this? I don't know much about these sleds is there anything else I should look at its got around 8000 miles on it
Confused
- Oct 12, 2008
- Mound, MN
- '25 Sidewinder SRX #723
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
1976 SRX 440 #554
Could be as easy as plugs and/or carb clean and adjustment. Otherwise more serious, but normal, would be valve adjustment.
RobX-1
- Coldwater, OH
Hopefully, the PO is aware of the choke lever since it's not FI and uses it during cold starts as I could see not using it causing hard cold starts. Other than that, I would agree with Confused in it could be relate to bad plugs and/or dirty carbs as well as the carbs being out-of-sync.
Pabstkiller
- Oct 20, 2021
- 2006 apex
how hard is it to do the valve adjustment? or is it something that should be taken to a shop?Could be as easy as plugs and/or carb clean and adjustment. Otherwise more serious, but normal, would be valve adjustment.
smokingcrater
How many miles, and when was the last time the carbs were cleaned? Valve adjustment is the last thing to check.
fuel filters can be an issue too but it is sounding like it is draining back from a pinhole somewhere. might want to blow in the tank vent line to see if it starts easier.
Confused
- Oct 12, 2008
- Mound, MN
'24 MXZ Neo+ 600
'88 SnoScoot
1976 SRX 440 #554
Depends how handy you are. Getting to the cam cover is half the battle. As others mentioned, start with plugs then carbs.how hard is it to do the valve adjustment? or is it something that should be taken to a shop?
Also, don't fix it for him while looking it over, the price becomes less negotiable.
Turbotim
- Feb 9, 2025
- central Alberta
- Rx1
mine had the same issue colder than -20c.going to look at an 03 rx1 and the guy says that its a real bitch to start when its cold. any ideas what would cause this? I don't know much about these sleds is there anything else I should look at its got around 8000 miles on it
I bought this sled and it had spark problems along with gummed up carbs, I fixed the spark problem and cleaned the carb, sled runs great but does not like cold starts, I had a choice to make, either modify to fix the issue or park it inside. I chose to modify it, now it starts with out cranking for ever on full choke. here is what I did.
