Started the vector today, it ran for a minute on full choke then it died. The sled would not restart unless full choke and some throttle applied. it would not idle. Any ideas?? Just had the carbs cleaned a month ago.
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
The plugs are probably wasted. I'd be willing to bet a new set would start with no problems at all.
STORM-CHASER
I would go along with rsvectorfreak and change the plugs
thats what I was thinkin too, I'll get em tomorrow. What makes em go bad? Only have 500 mile on her.
BigMac
- Jun 27, 2004
- Brainerd Lakes area, Minnesota
Fouling. Most likely caused by warming it up with too much choke. That's about all it can be unless something recently changed with your idle circuit.mk812 said:thats what I was thinkin too, I'll get em tomorrow. What makes em go bad? Only have 500 mile on her.
It's easy to forget to take the choke off properly. That's why I always carry extra plugs.
yammie3687
- Dec 14, 2005
I have a rage and a vector and have had this problem. I can tell you this, when you foul the plugs they are junk. Buy a new set and your sled will be fine.
FYI, stock plugs are NGK CR9E, around $3.00 at Autozone. Some folks are using CR9EK or CR10EK with good results, less fouling... more power with the 10's. The 10 is one range colder and and the K suffix stands for dual electrode. Do a search for tons of info.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Yamaha recommends CR8E plugs in the Vector.
Canadian Lad
Why are you leaving the choke on full for that long. I turn mine down to half as soon as it starts and gradually even less as it warms up so it doesn't foul plugs.
The fiche shows the 8, however, my Rage came with 9's installed from the factory.
GT Dave
Canadian Lad said:Why are you leaving the choke on full for that long. I turn mine down to half as soon as it starts and gradually even less as it warms up so it doesn't foul plugs.
What he said.....
I have 10's in my vector i actally picked up a little speed the drag strip.
jwalker2020
I have an 05 Rage and an 05 Vector, both purchaed at the beginning of the season last year.
In general, when starting cold, I put the choke at about 3/4 to 7/8. Never full choke. As soon as it starts, back off on the choke to 1/2. Modulate as needed.
They are defintely cold blooded, but once they warm up, it's a bucking bronco!
zigyqhouse1270
- Dec 14, 2005
listen to Canadian Lad there is reason to leave the choke on for a long period at all my venture almost all the time will start on 1/2 choke and once it is running i shut it right off had no problem at all runs great like a champ just the wheels and springs suck
