Carla 123
- Feb 27, 2017
- Manitoba
- 2015 viper xtx boosted
17 zr9000 precision stage 3
Stock 16 Ltx with tuners .6 inch carbide inside 2 inch outside steering really hard.should I drop front air shocks to around 60psi from 80 and loosen or tighten front track spring?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
If you add more preload to the front track shock spring it will take some weight off the skis. Taking weight off skis can result in pushing, so its a balancing act. If you really want easy steering check out my mechanical power steering kit (MPS).
Carla 123
- Feb 27, 2017
- Manitoba
Tuners push enough as it is damn sled costs more money than it's worth.cant win with this sled.never expected to do so much work to get this thing right .15k sled and another 2 just to make it right .Not impressed
work on viper mtxIf you add more preload to the front track shock spring it will take some weight off the skis. Taking weight off skis can result in pushing, so its a balancing act. If you really want easy steering check out my mechanical power steering kit (MPS).
