rdduck
- Jan 22, 2022
- Aylmer Ontario
- 2002 Yamaha vmax700er
I started blowing head light fuses,and need a good place to start to fix the problem.Help would be appreciated
Does it blow when the bulbs aren't plugged in?
rdduck
- Jan 22, 2022
- Aylmer Ontario
have not tried thatDoes it blow when the bulbs aren't plugged in?
rdduck
- Jan 22, 2022
- Aylmer Ontario
why would that have an effect?
I have seen a bulb that shorts out. Not very common, but I have seen it. Also check the harness didn't touch the exhaust.why would that have an effect?
This thread should be in the two-stroke side. Maybe one of the moderators can move it. @maim
do you have a https://totallyamaha.net/forums/ account rdduck?
have you checked under bar pad for mouse damage or botched heated sheild connections?
rdduck
- Jan 22, 2022
- Aylmer Ontario
yes
I do. Havent checked under bar pad .Heat shield not problem,as blew fuse when not using.I know there is no damage from micedo you have a https://totallyamaha.net/forums/ account rdduck?
rdduck
- Jan 22, 2022
- Aylmer Ontario
Heat shield connection is connected to the light system, as it was out along with tach and fuel gauge when fuse blew
