yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
So happy we haven't had a single starting issue on both our 2014 viper and 2014 zr7000! Both sleds starts right away each and everytime hot, cold never had the relay issue....or any of the other #*$&@ i read on here! Not sure what i have doing right but i am not changing my routines (sleds are alway in garage on battery tender when no in use, turn keys immediately no priming, always warmed to operating temp, hand thumb warmers alway off before start, new fuel at beginning of season) both sleds are running original plug and battery! I have no clue what is making both our 14's with original flash be as reliable as they been but i am not changing my routines..lol
I have even thought of changing our starters as a prevenative maintenance mesure but the starters haven't changed from 2014!
Fixit156
- Feb 6, 2017
- Holliston MA
- 2017 Yamaha Viper RTX DX
I also hope they release new update. It’s kind of sad when you try to start it when it’s minus 15F and takes 10 tries and backfires so loud everyone in your group starts ducking thinking some is shooting at them
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
Ever notice on all Japanese Yamahas the kill switch kills everything including starter yet on our Vipers Starter will still turn over even with kill engaged.
The Apex will crank with kill switch engaged as well.
I have had all the Flashes but have never had a issue Same no prime starting method as you,Original battery and Charge batt well every month during storage. Except for first year on original flash back in winter of 13-14 last ride of year warm temps like 50- 60 deg F here got P130 code and extremely low idle all within about 15 minutes just that one time. MtCooler had terrible HotStart issues everytime we would go for lunch. Original flash would refuse to start using all methods. I would like to see entire new wiring harness and a Mitsubishi Yamaha programmed ECU to go with it. Eliminate the draws and fix the programming Cat cannot seem to get right. But all issues have been livable for ours. Always thought if I lived in a remote area it would really concern me enough to go buy a simple 2 st like Yellowknife did. That was till this weekend when at -15f all the 4 st's started fine and my buddies 16 800 Cat just refused to start and flooded itself out beyond belief. Common denominators? Its a Snowmobile and its a CAT!So happy we haven't had a single starting issue on both our 2014 viper and 2014 zr7000! Both sleds starts right away each and everytime hot, cold never had the relay issue....or any of the other #*$&@ i read on here! Not sure what i have doing right but i am not changing my routines (sleds are alway in garage on battery tender when no in use, turn keys immediately no priming, always warmed to operating temp, hand thumb warmers alway off before start, new fuel at beginning of season) both sleds are running original plug and battery! I have no clue what is making both our 14's with original flash be as reliable as they been but i am not changing my routines..lol
You sure about that? Never saw a Yamaha that did that. Well there goes that theory. Who knows? Sometimes its best to either scrap the whole system like Griz did with Nytro conversion or just live with variables and be happy. I have chosen last option for forseeable future.cannondale27 said: ↑
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
I will need to confirm
Chief Gotta Go
- Feb 14, 2018
- Frankenmuth Michigan
- SR Viper LTX
My 2015 (Turbo) (Cold) takes two times to start . First time it stumbles .....if you rush the second start it cranks for a bit ......if you wait a few seconds it hits right away on the second try ....its annoying as hell , Once in awhile it will start on the first try . if I hit the start as soon as I power on it will crank and crank ..Now I wait till the fuel pump stops .....then it stumbles on the first start .....then runs on the second .....Has done this from new .......not sure if it has been flashed . Bought of the floor as a left over late 2016 and added the yamaha turbo kit .Sled has 600 miles on it now .....and has a 2018 engine due to a improper flashed altitude compensator ...that did not get caught in the 2016 recall ......Another story and 2 engines
yammitrip1
- Sep 28, 2017
- Rome ny
- back country sx viper, trail sx viper s
So how about that new flash?
It’s fine for me. Sometimes I do need two tries to start but majority it’s first crank. Definitely can tell it cuts ignition if cranked to long to prevent kickbacks. That’s good. I recommend it still.So how about that new flash?
yammitrip1
- Sep 28, 2017
- Rome ny
I have to get the new flash must be, I think mine is the 14 orginal one
TD Max
It really should be cutting the fuel and leaving the ignition on. Cutting the ignition is what is causing the kickbacks. The cylinder and exhaust fill with fuel then when ignition resumes it goes boom.
The $64000 questions: Does the ignition drop due to a logic function of the ECM or a voltage threshold within the ignition module itself? And from there is this a designed in feature or is the voltage simply falling below the basic design limitations of the module?
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
Both of our 15s have the latest Flash and they definitely start a lot better and Idle better. Like others have said occasionally will require 2 starts when they're cold But that's no big deal thats way better the a kickback and busted teeth which both of our sleds had happen with the original flash. Get it done guy's.
cobrajet ltx dx
What everybody has to understand, these mapping issues have different effects depending on the climate you ride in.For me it’s ridiculous in -30 in Quebec with the the shot gun blasts on start up that only occurred with the latest flash.For others it’s fine because of the climate differences.
Had a interesting conversation with a dealer in Fort Kent Maine this past week while saddlebagging,they said Yamaha is working on ANOTHER FLASH and aware of my certain issues when starting in severe cold conditions.
They also said they have been flashing there customers ecu’s with evo’s 91 octane map only using the 2014 mapping tables with excellent success.
I have over 8k of seat time on my 15 that is completely bone stock and Yamaha better straighten these issues out because a lot of people are FED UP and I’m one of them.
TD it may cut fuel. I don’t know but whatever it does it’s almost like engine is coasting. No resistance. Sure seems like it would help eliminate kickbacks.It really should be cutting the fuel and leaving the ignition on. Cutting the ignition is what is causing the kickbacks. The cylinder and exhaust fill with fuel then when ignition resumes it goes boom.
