dylanjen9
dylanjen9
dylanjen9
doesnt coolant go in one side on out the other?
dylanjen9
If you can't blow thru then it is blocked. Coolant needs to flow thru it. You could try some Rad Flush. Pour it in, let it sit and then flush it out.
krm
- Apr 22, 2016
- ny
Put some water to it with a garden hose .See what happens then ,Simple
dylanjen9
Put water in it then air from compresser and nothing comes out aluminum actually blows up like balloon from air
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Definitely plugged up then.
nydiver
- Apr 30, 2015
- Syracuse, NY
- 09 Nytro XTX
09 Nytro RTX
91 Phazer II (gotta have a classic / kids bomber :) )
Someone sold you a lemon, try filling both ends with some vinegar, let it set for 30 minutes or so, then flush both directions to see if you can dissolve the blockage. Don't try using air you'll just blow it up, minimally invasive is what you need to try, liquid plumber would unstick it, but then it would also straight F the aluminum up.
