ChiefMn
- Aug 25, 2013
I hate having to scroll all the way thru the settings to turn the warmers down.Anybody got a fix?
2008 Nytro RTX
2008 Nytro RTX
Hooray!
- Aug 12, 2017
- Maine USA
- 2009 Yamaha FX Nytro XTX
1998 Yamaha VMAX 700 XTC
Lol... Nope. I thought the same thing first time I used it and if you go one press too far around the barn again!
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Yeah I know what you mean. The Phazer I had before I picked up my 08' Nytro has the same set up for the heated grips. You could look at installing a Yamaheater and then talk with Rock about adding a switch. The original or very first Yamaheaters Rock put out had a master toggle switch. So you could keep the grip control at full Yamaheater hot then turn them off with the toggle switch. So you would alternate between super low heat and Yamaheater full hot heat. I am sure Rock could come up with something like this if it makes any sense? G.B.
Hooray!
- Aug 12, 2017
- Maine USA
I guess that is what mine has. I set yamaha heat level when cold flip up toggle, when warmed up flip toggle down as I recall. There is a red green led too I think... Forgot already how it works... Lol... Winter is coming : )
Dr. FeeLGooD
I have a set of dial controls off my old 03 Viper. Often thought about wiring those in and leave the factories on high. Just scared I may ruin something. Anyone try something like that?
AftonJay
- Oct 23, 2012
- Northern Michigan
- 2005 Warrior, 2009 Nytro XTX and Arctic cat puma for the kids
- Afton Mi
Could you use the controls off an RX? Mine had what looked like the exact same switch but had one for the grip and one for the thumb and you could go up and down. Heck the Nytro handlebar switch housing on the opposite side even looks like it has a knock out for the toggle.
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Yep, you have the very first generation Yamaheater on your sled. That's great to see it still in use and working. G.B.I guess that is what mine has. I set yamaha heat level when cold flip up toggle, when warmed up flip toggle down as I recall. There is a red green led too I think... Forgot already how it works... Lol... Winter is coming : )
yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 12 Nytro XTX (mine)
06 Apex GT (wifes)
07 Phazer (#2 sons)
02 Viper (#1 Sons)
I run at 1 bar short of full, seem to work better.I hate having to scroll all the way thru the settings to turn the warmers down.Anybody got a fix?
2008 Nytro RTX
