Chrishall11
- Dec 16, 2011
Hi All,
Plug is not working for my visor. Manual shows fuse box located under left side panel. I removed it but can't find the panel. I can only find what looks to be big square fuses. Can someone tell me which panel the fuse box is under so I can see if the fuse is blown for my visor? Visor work when hook up directly to battery.
2010 XTL
Cheers,
Chris
2010 XTL
Cheers,
Chris
IH8CROWS
- Jan 19, 2009
- Wisconsin
- 11 Apex
16 Apex
Right side panel. Near the reverse lever.
Banks93
Remove the Right Panel and it is at the top in a little square black box. The front 3 amp fuse is the shield fuse. Most likely it is blown because the plug hit metal. There should be a replacement fuse in the little black fuse box.
