sabrecat
Vendor
- Nov 7, 2013
Your stock rear trihub is a failure waiting to happen. The stock set up uses small bogie wheel bearings to hold track tension and the wear and tear we put the sled thru. Broken trihubs have ripped tracks and can also lock up your track. The J&T Products wheel kits uses heavy duty wheels with much larger bearings. In fact the bearing is about twice the size and that will make the big difference. Always priced to be affordable.
Stock 7.125 diameter wheels 129 inch tracks $119.95
Stock 8 inch diamter wheels 137 and longer $129.95
www.jtatv.com
www.jtatv.com
Kevin
Will these work with the Yamaha 4th wheel kit ?
sabrecat
Vendor
- Nov 7, 2013
Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
Yes it will.
Thx
That's great news. Glad someone asked. I had gotten the outside Yamaha wheels when I purchased my SW LTX LE. Just assumed the JT wouldn't work with them and would have to choose one or the other.
