Heavy Hitter ?
I didnt know that was an option :? A dealer has one in stock he is a ways away form were i live He wants $230 I not sure what all comes with it
thunder products
Is anyone for sure if the HHs will work in the 04 warriors clutch?
BBy how much can you get a set of HHs for?
I want HHs in my sled but am not sure if i want to change helix what advantages do you gain from them.
I just want alot better holeshot advantage
welter and toold, hang tight. I am will have my new pricing soon. Ill take care of both of you. I can sell you just the HH's, or can set you up with the package. HH's, Helix, and Secondary spring. Ill keep you posted. Should know in about a week...BBY
this might be doumb but what should i exspect by changing the secondary springs? the preload etc.& the wrap it is on.
Secondary Springs
The spring you use determines how the secondary will up shift and backshift. A stiffer, stronger rate spring will upshift slower and backshift faster. A lesser rate spring will upshift faster and backshift slower. The conditions you ride in dictate what spring you would use.
