Keith Schmitz
Whats up? My 17 RTX is getting a Precision multi map & dash flash today. I’m curious to OPINIONS on which helix a guy could/should run. I only ride on trails.
I also readily admit i don’t really “understand how they work”, there are tons of options, and just wanna know which one & why.
Thanks!
Thanks!
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
The million dollar question.........
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Honestly, Id be more concerned with other aspects of clutching, stock helix is not bad.
Need a ton more info too....
Dan
Dan
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I wish Shockwave made an adjustable helix for Sidewinder, but they don't,,,,,,
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I believe it is G-force that makes one.I wish Shockwave made an adjustable helix for Sidewinder, but they don't,,,,,,
Dan
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Yeah you won't notic a huge diff with a degree here or there. Spring choice and wind will be more crucial depending on your needs. Stock helix works well.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
You’ll need weights,springs, helix with that tune and she will fly.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I have that one. it is great for quickly changing spring wrap.I believe it is G-force that makes one.
Dan
Shockwave makes one that the ramps are adjustable, giving you up 20 degrees of adjustability without removing the helix.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Gforce offers other ramps to swap out in helix, 37 is lowest I see.I have that one. it is great for quickly changing spring wrap.
Dan
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
A lot of options and opinions. Many factors. If your after corner to corner and a nice pull on a punch at 60 GO straight 38 or 40. If you want big top end a lower finish like 39/35.
Keith Schmitz
Ok, as far as other info...
I have Thunder clutching (set up by Terry). I have the Pro4 clutch. Orange secondary spring. All other rollers n stuff changed. What other info needed? As far as trails go, it’s mostly upper Wisconsin, so a mix of twists & wide open long straights.
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
Just my 2 cents, I'd probably just use the straight 35 it comes with. If you are a trail rider you'll get a good backshift with that.
BTW, a good fireside read:
https://www.amazon.com/Clutch-Tuning-Handbook-Updated-B-16003/dp/B0055DOXXW
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
The pro 4 clutch changes things. I would think that is going to be slightly different then what most are running. Yamaha clutching is what your going to get set ups for. Keep us informed on this clutch. Thanks
Jon
Jon
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
I think he means he has a pro4 primary no?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Pro 4 I was assuming is the primary that Thunder is selling? All billet? Maybe I’m off
