dzglaser21
So my problem started last season in a middle of a ride. Occasionally when starting from a dead stop, sometimes my sled won't move and the belt just starts smoking. Its happened from first time getting on the sled for the day and it has happened after stopping to cross the road. There is no rhyme or reason to it and happens very random. I have no clues so any help will be greatly appreciated.
Turk
Tech Advisor
Your secondary is probably stuck 1/2 open. If you come to a sudden stop or your secondary cam buttons are worn out this will happen.
dzglaser21
Turk said:Your secondary is probably stuck 1/2 open. If you come to a sudden stop or your secondary cam buttons are worn out this will happen.
How do i check that and/or fix it??
woodchk454
maybe a previously blown belt left pieces inside secondary causing it to stick??
Yamadog
Yeah if your buttons wear a flat spot can occur and they wont slide on the helix ramps.
Len Todd
The effect you are experiencing most-frequently occurs if you slam on the brakes and not release them to come to a stop. When you lock the brakes to a full stop, the Secondary will not recover to low gear, so to speak.
The best way to avoid this is to allow the sled to come to a rolling stop. Once you get used to not having to chop the throttle and slam the brakes to make a turn, it kind of comes natural to allow the thing to come to a rolling stop. It's just an awareness kind of thing.
