darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
im 335lbs purchase kit from boss an lost set up info and try to get a hold of them an on answer. purchased about 2 years ago just didn't put them in had to deal with cancer treatment. any help thanks.
yox185
darv
- Aug 9, 2005
- 08 Apex 40th LTX
I have that but the boss was different.
What sled is this for?
darv
- Aug 9, 2005
- 08 Apex 40th LTX
08 apex ltx
It is for an 08 Apex 40th LTX I know I was to use the black spring or the yamaha O-S- O but I forgot what I was to set in the weights lost sheet was dealing with health instead.
Rich Kay
Hi Darv, Go to there website www.heelclickerclutching.com/‎ and click on the yamaha drgon fly kit and it will give you the option to open up the instuctions for loading the weights along with all the other info on setting up the kit....Its the whole intruction sheet in PDF forum.. Hope this helps. Keep tring to call them on there number listed you will get someone sooner or later. Randy is the guy to talk to if at all possible.darv said:im 335lbs purchase kit from boss an lost set up info and try to get a hold of them an on answer. purchased about 2 years ago just didn't put them in had to deal with cancer treatment. any help thanks.
Rich.
darv
- Aug 9, 2005
- 08 Apex 40th LTX
That's the problem I need the. Number anyone have it.
yox185
Heelclickers number (320)632-4749
Rich Kay
darv
- Aug 9, 2005
- 08 Apex 40th LTX
Guys I have the set from HC Boss used a different set up than them and he uses tha OSO spring I instead of the black I need the set up info that Boss recommended that what I lost.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
did u ever find the set up?Guys I have the set from HC Boss used a different set up than them and he uses tha OSO spring I instead of the black I need the set up info that Boss recommended that what I lost.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
I have a real good set up for that application. Let me look for it if anyone is still interested.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
yes please do id really appreciate it thanks
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Stock secondary
Black hc primary spring
bolt + washer in the heel
bolt in the center
1/2" set screw in the tip
bolt + washer in the OD.
After you set this up and run it, try a silver secondary spring and compare to the stock pink. I have had luck using a softer spring in the secondary with this set up on some sleds.
bolt in the center
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
this will work in a 2014 apex also? might have to do alittle adjusting do to little more power than 06-10?Stock secondary
bolt in the center
