3six7
Are there any tricks to getting the skid back in on the 141”? I am trying to use front bottom and rear middle mounting holes and it doesn’t seem like I can get enough slack in the track to line everything up.
Kenneth Rogers
- Jan 23, 2019
- Fort McMurray, Alberta
- 2021 Sidewinder SRX LE
2018 sidewinder xtx-se 137”
1997 Vmax 4 800 shorty
1996 Vmax 4 800 shorty
1995 Vmax 4 Improver
1994 Vmax 4 St
1993 Vmax 4 800
1990 Phazer
1989 Bravo
1980 SRX 440
Compress the rear shock with a ratchet strap.
Mtnviper
Vendor
If you have a rear Float shock, you can let the air out of it. Also sometimes it's easier to install with the sled laying on it's side. I usually will put a piece of carpet down to help prevent scratching the side of the sled.
You'll want to align and install the front arm bolts first, then the rear. A Phillips screw driver or punch also helps when aligning the front mounts.
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
If you're doing it by yourself definitely helps to have a ratchet strap to line up the rear mounting bolts.
3six7
If I put sled on it's side, which side do I have to have it on to not dump any oil out?
yamahaguy
Ride SAFE
- Apr 20, 2014
Oil tank side down clutch side up. that will keep the air oil separator higher than the oil level so it won't spill back out through the vent.
