Kryton619
- Dec 28, 2019
- 2004 Yamaha RX Warrior
2003 Polaris 600 XC SP
Can someone please let me know what the purpose of the hose is in the attached picture? It is located right behind the coolant bottle and has what looks like a spring around the bend.
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
Just a fuel vent/vapor hose ,the spring is for abrasion resistance&to prevent kinkingCan someone please let me know what the purpose of the hose is in the attached picture? It is located right behind the coolant bottle and has what looks like a spring around the bend.
Kryton619
- Dec 28, 2019
Thank you! So the end of this hose is what some people use to pressurize the tank when the fuel pumps and carbs have no fuel in them?
Brotherdan
- Sep 8, 2017
- Belmont,maine
Yeah some do,my sled didn’t really work/start that way.best way I’ve found after my sled has sat along time is to remove the airbox cover&spray fuel in carb throats with an old windex bottle etc mine fires right up this wayThank you! So the end of this hose is what some people use to pressurize the tank when the fuel pumps and carbs have no fuel in them?
RobX-1
- Coldwater, OH
EDIT: Actually, the hose I use to pressurize the fuel pumps is located on the left side foot well, just above it, where the hose plugs into the stem with the red arrow pointed to it in this picture:
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
That's actually the left footwell in your picture. Just like a car when you are sitting in it, that's the left side of the sled.
RobX-1
- Coldwater, OH
Thanks trasher for pointing out my mistake. In my haste in posting, I was trying to state that stem is "right" above the foot well and for some reason had right foot well in my head. Correction has been made.
Brotherdan
- Sep 8, 2017
- Belmont,maine
It’s the same hose he referred to in initial pic,comes out of top of tank loops around right side&goes over&down left side,it actually does not go to fuel pumps but is a tank vent line &when blowing in it it puts air pressure into the tankEDIT: Actually, the hose I use to pressurize the fuel pumps is located on the left side foot well, just above it, where the hose plugs into the stem with the red arrow pointed to it in this picture:
RobX-1
- Coldwater, OH
Yes, I realize it's the same hose but wanted to point out where it ended to avoid him from having to trace the hose. Although the hose is in fact a gas tank vent hose, blowing in it will pressurize the gas tank and force fuel to the pumps so I probably should have stated "primed" the fuel pumps rather than pressurize them.
Brotherdan
- Sep 8, 2017
- Belmont,maine
It’s all good just wanted him to realize it was all the same hose that looped right to leftYes, I realize it's the same hose but wanted to point out where it ended to avoid him from having to trace the hose. Although the hose is in fact a gas tank vent hose, blowing in it will pressurize the gas tank and force fuel to the pumps so I probably should have stated "primed" the fuel pumps rather than pressurize them.
