Corey9965
I'm stranded on the side of the trail with my 09 nytro rtx with code 33. I called Hauck and they said its an open circuit on cylinder 1. Any help would be great.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Check the connections to the spark plugs?
Corey9965
Changed 3 plugs on trail still no change
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Also, check spark plugs and wires for rubbing, wear through.
Maybe unplug/plug ecu
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Swap the ignition coils around to see if it changes to a 34 or 35 code
apracing
- Feb 19, 2013
- new brunswick
- 2004 rx1 warrior 2006 apex gt 1979 enticer 340
is the wire harness rubbed through just behind the primary clutch ??
apracing
- Feb 19, 2013
- new brunswick
did u find the problem ,not mine is doing this ??
- 55K
