ApexTom
- Sep 20, 2022
- Fredericton, NB
- 2012 Apex XTX
2007 RS Venture
Hi, I'm new to this forum although I have followed TY 4 Stroke for the past couple of years.
I am installing a temperature gauge on my 2012 Apex XTX and need to know the best/easiest locations to tap in to the 12V and Ground wires. Reading through the other temp gauge installation blogs, the blue/white wire is mentioned, but I can't seem to locate it on my sled.
Any help would be greatly appreciated - pics would be amazing!
Thanks!!!
Thanks!!!
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
You can just tie into the 12v accessory on left side of key switch panel. This is fused circuit and is energized once sled starts.
ApexTom
- Sep 20, 2022
- Fredericton, NB
- 2012 Apex XTX
2007 RS Venture
Thanks for the quick reply (and your Apex expertise). Any idea about the colour of the 12v wire?You can just tie into the 12v accessory on left side of key switch panel. This is fused circuit and is energized once sled starts.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Off hand I don't recall which wire is ground vs hot. I can check later
ApexTom
- Sep 20, 2022
- Fredericton, NB
- 2012 Apex XTX
2007 RS Venture
Thanks - greatly appreciated!Off hand I don't recall which wire is ground vs hot. I can check later
There is only two wires and the black is ground.Thanks for the quick reply (and your Apex expertise). Any idea about the colour of the 12v wire?
