MarkRTX
I've been trying to get a hold of him the past few days but to no avail I believe he sent me a setup last year but deleted it by mistake. I know hes in business and most likely won't share his latest and greatest setup but I know hes a great guy and will compensate him if needed thru either passing his name on to friends or whatever the case may be. He has to make money somehow I do understand that. Thanks for evryones help especially you Turk you take the time to help us guys new to clutching. One more thing I have heard you say tight track for better speed but how tight is tight I may have adjusted mine to tight which would rob lots of power I would think. Thanks again Mark
Turk
Tech Advisor
You want your track just tight enuff so that if your going down a hill & let off the throttle the sled will still coast. If it stops going downhill on hardpack it,s too tight. That,s not really scientific but it,s how i kinda guage mine.
RJH
had a few sightings over the past weeks on my lake...you guys better get them going...seem to start well...then get pulled...
maybe its the same guy going both ways....
If you were only pulling 110-111mph then yes you will get beat everytime. STOCK f7's run 115-117 right out of the box an glare ice. F6's run 110-111 right our of the box. I have tested and clutched for countless hours on Firecats. They have ridiculous top end !!
CANAM 4 Stroker
- Oct 26, 2005
- www.klim.com
- 2009 Yamaha Apex GT
MarkRTX,
Did you have better success this weekend with the D&F changes ?
piped bravo
sounds to me like the 2-3 inchs of loose snow was the main difference.....try him on hard pack and see were things are....changing all you set-up might just get you chasing your tail.....my buddy has a well running Attck that can spanks me all day....put a couple inch of loose snow in the mix and he is looking at my tail light (XTX)
welterracer
I had a very light buddy 155lbs.. who had a well set up 05 F7 snopro.. 2degree key, pipe mod, can, clutching, snopro track with 168 studs, etc and it ran hard..
But i still beat him stock.. but if he got the jump on me i never got more than a sled or two ahead of him in the midrange
Dont know how your attack would be getting beat other than he is getting more traction..
Take the transfer rod out.. lean as far forward as you can and say BYE BYE to him
I never lost a race wth my transfer rod out.. Massive Hookup
