yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I got this sled In for maintenance and to repair the antifreeze leak.
As many of you know it's not a quick fix to replace that little 0.50$ peice of hose In the front of the tunnel (chaincase side)!!!
To replace this hose the gas tank, manifold cover, extension pipe , skid , track/driveshaft all have to come off.
Then you need to drill out the rivets connecting the coolant pipe running down the tunnel to the rear heat exchanger. The 2 nipples are only 1/4" apart so it's impossible to put the new hose on with pipe riveted to the tunnel!!!
Do your self a favor and either make the covers or buy them from Travis at Barn of parts if you haven't already!!
2021 has a new braided hose replacing the rubber one. IMO it will be much easier to add the covers then upgrading to braided hose for any sled pre 2021
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
IMO that’s another half assed production issue. Can’t believe they actually sent sleds out with that BS connection. I put Travis’ guards on as soon as I saw that.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
It's a total hack job!! I can't believe they cut out slots in the tunnel for the gear clamp bolt..lolIMO that’s another half assed production issue. Can’t believe they actually sent sleds out with that BS connection. I put Travis’ guards on as soon as I saw that.
RAMSOMAIR
I had some reservations when I first installed the BOP guards 3 years ago! I was concerned they might rub the bottom of the exchanger and my thoughts were correct. I pulled them today while doing some maintenance and since Marc had just posted about this. You can see where they have rubbed into the aluminum and wore it down a bit. Now I think the extrusion is thick enough anyway but perhaps Travis could give us the same guards but maybe bend them with a 1/16”- 1/8” more clearance????
4strokes
- Mar 13, 2018
- charlemont ma
- 18 winder xtx 09 nytro xtx 06 apex gt
pics????
RAMSOMAIR
Here are a couple pics
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Marc your 2nd pic shows the hose deformed, was it like that before you got working on the sled ?
RAMSOMAIR
I will still put them on my new sled!!!
NYTurbo
STM tunnel protectors do a very good job of protecting it
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Yes I am guessing the tunnel iced up and pushed the gear clamp causing the it to puncture the hose when he took ofMarc your 2nd pic shows the hose deformed, was it like that before you got working on the sled ?
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Ok thanks makes senseYes I am guessing the tunnel iced up and pushed the gear clamp causing the it to puncture the hose when he took of
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Can we add a bead of silicone or something at the bottom of the protector before you install it ?I will still put them on my new sled!!!
Just thinking if we put something between the two pieces of aluminum to insulate the two
from rubbing. I installed the protectors at the beginning of the season.
sailor joe
- Apr 4, 2019
- ma
- 2016 RS VENTURE TF
2020 SIDEWINDER GT
oh man, what a disaster if it takes so much reaching to fix a hose...lookslike the machine has to be almost ripped down completely...what's the fix to avoid this? A BOP tunnel protector? Do I got this right?
WinderFab
- Mar 1, 2009
- Woodbridge, ON
