yamaha06
I have installed the Sled Start HID bulbs on my nytro 3 years ago. I noticed today one of the bulbs isn't working so I figure its probably blown, has anyone else had one of there HID blow, I figured being HID they would last a lot longer then 5500km. Anyone know what bulb or part number to look for? I see sled start wants like $120 for 2 bulbs and they only come in pairs. But if I can buy another bulb that will work for cheaper that would be sweet! Thanks.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Buying only one bulb might result in a color difference between the two. A friend purchased new sledstart bulbs but replaced just one and noticed a difference in color between the old and new.
yamaha06
Buying only one bulb might result in a color difference between the two. Sled start sold a single bulb to a friend which doesn't match his original so I'd buy the pair and keep one as a spare. You can buy a DDM kit cheaper than the replacement bulbs.
wow they are way cheaper, wish I would of known about these guys 3 years ago before I dropped $200 on the sled start HID's. Do you know if these bulbs would work with the sled start HID kit?
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
I'm not sure but I've been running them for 4 years with no issues.
I would talk to Rock... sometimes the ballast goes out and then the light wont fire. The lights maybe fine.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Rotate the bulbs or swap the ballast connections to determine if it's actually a bulb or possibly a bad ballast.
Tyloooor
try sledtoyz.....their in ontario and should be able to help...if not rock is the best
68ozzy
- Jun 2, 2014
- nytro
Hey Grizz where did you buy yours from ??? All I can find are for motorcyles nothing sled specific
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
DDM HID Kit With Slim Ballast- 35W or 55W (Xenon)
NS FX NYTRO
^ that kit is by far the best bang for the buck. Mine is getting a set this fall. I have friends who run this ddm kit in their vehicles and atv's without any issues.
Yannie
- Jan 5, 2014
- Winnipeg
- 2010 Yamaha Nytro RTX
"Link removed per admin"
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
U think ddm with still warranty bulb after u modify them? How much better is it after the mod? Still debating what I want to do.
HID antiglare shields are separate from the bulbs and all that you're modifying is the shield. I don't think you'll ever need a shield warrantied.
nitris223
- Nov 18, 2012
- Yorkton Saskatchewan
- Yamaha Nytro MTX
The newer HID bulbs are different then the one Grizz posted. I did not notice much difference when I switched from low to high. High maybe shinned a tad bit higher but they are so much brighter on low and show a ton more area that high beam is not really needed. Here is a picture of what the bulbs look like now. I bought my kit last year. Second picture shows 2 nytro's parked 5 feet apart and both sleds are on low beam. Hard to see the sleds but they are there and I was standing in the middle taking the picture.
Needless to say the other guy wanted me to install a set of HID's into his sled the next day.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
I knew they updated the shields and bulbs last year. I might have to buy a set and try them.
