Firecat_Freak
How much and where can u get this HID kit?
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Sled start is plug and play with excellent customer service.
http://www.sledstart.com/HID_lights.htm
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
- ramody44@yahoo.com
race24x said:Should I bring a long screw driver for my first ride? Are they that far off after install? I assumed the lights wouldnt need to be adjusted much
Yes, I would be prepared to realign your high beams to how you would like them.
Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
Maybe you guys knew this already, but I wanted to share how I make a quick headlight beam adjustment on my RX / RS:
Use a 5 mm allen wrench or T30 torx driver to loosen the right rear screw that fastens the key switch panel. Wedge the panel open and use a long Phillips screw driver (at least 14" past the handle) to turn the headlight adjuster screw. Remember to carry a small flashlight.
Sorry, sled is covered in shop dirt...LOL!
Redbeard
- Oct 14, 2011
- IN
One more thing, there are ways to fit all the HID components up inside the headlight pod. That way you don't have a dozen different wires to disconnect when you remove the headlight for service.
The link below shows what I made for my Apex. There is also another link from BETHEVIPER that gave me the idea, so the credit goes to him.
