WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Other day I removed the battery tender from my sled rolled it out on the drive way and fired it up for the first time this year, as I let it warm up I switched on the high beams and it took 2-3 seconds for the lights to switch to high and about the same time to switch back to low beam once I hit the switch.
Tried several times switching from low to high beams and it always did this delay.
Ran all last season with Roc’s hid kit and never had a problem.
Has anyone experience this before? I’m thinking maybe the headlight switch or something else as I don’t think it’s the actual hid kit doing this.
Yes, I had the same problem.
Get in touch with Roc, he’ll take care of you.
RobX-1
- Coldwater, OH
If I'm not mistaken, with his HID kit when you toggle the hi/low beam, it's suppose to move the light bulb up or down as I recall Rock mentioning that when assembling them, he always checks the bulb to ensure you can press lightly down and allow it to return since he uses silicon and that can some times cause the bulb to stick. Wondering if something is lightly restricting the bulb from moving and causing the delay. But as rpc1018 suggested, get a hold of Rock as his customer service is second to none.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Thanks guys
I thought maybe the switch was sticky or not making good contact but I’ll give Roc a txt and see what he says..
