1. We are no longer supporting TapaTalk as a mobile app for our sites. The TapaTalk App has many issues with speed on our server as well as security holes that leave us vulnerable to attacks and spammers.
    Dismiss Notice
High elevation proven Mcxpress stage 3
Discussion in 'SideWinder Mountain Talk' started by Jakeshupe79, Jan 5, 2019.
  1. Jakeshupe79
    Jakeshupe79 Veteran
    35
    Grace
    Country:
    Snowmobile:
    2017 yamaha sidewinder evo tuning
    Tarzan likes this.
  2.
  3. Roughriders
    Roughriders Newbie
    15
    Sask
    Country:
    Canada
    Snowmobile:
    Sidewinder
    awsome!! any info on the sled? what boost level he running ? what elevation?
    Jakeshupe79 likes this.
  4. Jakeshupe79
    Jakeshupe79 Veteran
    35
    Grace
    Country:
    Snowmobile:
    Thanks. I have the mcx stage 3 with the bigger turbo and intercooler. I put a 175×2.8 with the 3.5 pitch track. It also has the belt drive with higher gearing. Running 22 psi boost at 10k ft.
    Tarzan likes this.
  5. canuck5
    canuck5 Extreme
    94
    Sylvan Lake Alberta
    Country:
    Canada
    Snowmobile:
    Yamaha Nytro MTX
    What a monster that would be. How much does throttle response change over stock? And what octave are your running at that elevation with 22psi?
  6. Jakeshupe79
    Jakeshupe79 Veteran
    35
    Grace
    Country:
    Snowmobile:
    The throttle response is actually a little better then stock. And running straight 110 race fuel. Its definitely a handful of fun.
  7. canuck5
    canuck5 Extreme
    94
    Sylvan Lake Alberta
    Country:
    Canada
    Snowmobile:
    Yamaha Nytro MTX
    I’ve always liked MCXPRESS gear time and again runs strong. Just hard to justify the extra turbo expense when the stocker works so well
  8. Jakeshupe79
    Jakeshupe79 Veteran
    35
    Grace
    Country:
    Snowmobile:
  9. Roughriders
    Roughriders Newbie
    15
    Sask
    Country:
    Canada
    Snowmobile:
    Sidewinder
    how do you like that track?
  10. Jakeshupe79
    Jakeshupe79 Veteran
    35
    Grace
    Country:
    Snowmobile:
    I like it a lot . Pushes forward in the fluff and bites hard if there is a base. I had the CE 174×3.2 on it last year. I didn't care for that track. Almost seemed to soft. I did need to change the drivers to a 6 tooth just because of the 3.5 pitch. But I offset that by putting 1.84 gearing in it.
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
