full tilt viper
- Dec 25, 2009
- Nytro MPI Stage 1
Running Apex mcx 200 kit . Will a lower engagement give you better hole shot ? Is it better to come out of the hole softer and build boost slowly so you don't blow out the track ? Have dalton B/S ,B/O and a bunch 0f Yamaha springs WWW, YWY,BPB,BWB,GSG,YSY to pick from.
full tilt viper
- Dec 25, 2009
- Nytro MPI Stage 1
Anybody ?
kviper
I had a 12 Apex with the MCX 200 kit. I 60 footed the best on hard pac around or just under 3,000 rpm. It was a 129 with 192 studs that were ground on the leading edge to create a flat face. Transfer was set just so the skis were just off the anow.snow. also had MSD launch master on it.
full tilt viper
- Dec 25, 2009
- Nytro MPI Stage 1
Hey thanks, do you remember what primary spring and you stm set up ? I'm running a YSY glide washers @83 @ 2 Tung 4 mid 3 tip white secondary. . Surprising how much weight these can pull. Mt 290 Cat was 79G strange. Going to try the dalton B/S 41/125
kviper
I sold that sled two years ago so sorry I Don't remember what springs I had in it or exact weight and placement.
