out-front-Y
I am installing a hks electronic valve controller. And it has more features then i am going to use right now. To make this work do you need the rpm and throttle signal hooked up? Also my wastegate has a nipple for boost and one for vacuum can anyone tell me what hose goes where.
thank for any info!
thank for any info!
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
Re: HKS Controler
You don't need the RPM or TPS hooked up for it to work.
The little hose goes to the carb or throttle body vacuum source.
Center nipple goes to compressor housing.
The end nipple goes to the wastegate.
Ted.
out-front-Y said:I am installing a hks electronic valve controller. And it has more features then i am going to use right now. To make this work do you need the rpm and throttle signal hooked up? Also my wastegate has a nipple for boost and one for vacuum can anyone tell me what hose goes where.
thank for any info!
Ted.
out-front-Y
Thanks Ted
Ok the end nipple goes to the wastegate but on mine i have two nipples one marked boost. What one do i go to. And what do i do with the other one.
thanks
thanks
FLYBYU
look at your instructions, it shows installs for both types of wastegates
FLYBYU
here you go, dual port actuators instructions . hks V http://www.hksusa.com/content/pdf3374.pdf
out-front-Y
Thanks missed that pic.
- Sauk Prairie, WI
- www.ty4stroke.com
HKS Controler--Help Ted
Ted, regarding the little hose that goes to the throttle bodies, can you "T" in anywhere on the throttle bodies or does it have to "T" before the regulator "T's" off to the throttle bodies?
Thats a mouthfull, but we went to install a HKS tonight and had a hard time trying to figure out a good place to "T" in for the vacuum source.
Ted Jannetty said:out-front-Y said:I am installing a hks electronic valve controller. And it has more features then i am going to use right now. To make this work do you need the rpm and throttle signal hooked up? Also my wastegate has a nipple for boost and one for vacuum can anyone tell me what hose goes where.
thank for any info!
Ted.
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
Use the 4 Nipples on the engine side of the Throttle bodies, T them all together and connect to boost gauge on HKS unit.
- Sauk Prairie, WI
- www.ty4stroke.com
Thanks for calling Ted. I really appreciate it.
