apexgt4life
What are u guys using to hold primary when removing and installing to torque without having proper holder?
mrtwostroke
- Apr 24, 2003
- Sweden,Lulea
- Sweden
- Sidewinder MTX 240 Tune Sidewinder XTX 240 Tune MountainMax SL 153.
I use the handel of a broom for many years.
And sweep the garage floor.
apexgt4life
How u holding. Sliding handle thru center i assume
zx4ever
- Apr 14, 2011
- Northern BC canada
- 08 nytro ty4stroke customized
I use a ratchet strap hooked to clutch and then tied back to running board in the opposite direction of the way your turning.
mrtwostroke
- Apr 24, 2003
- Sweden,Lulea
- Sweden
Yes you are correct.
Dusty Dan
- Jan 24, 2015
- 2016 SRViper LTX LE
2012 Vector
I used a piece of wood with small wood blocks screwed to it. It is mounted in a large vice and worked slick.What are u guys using to hold primary when removing and installing to torque without having proper holder?
apexgt4life
I feel like that would distort running board
What about secondary jackshaft with secondary off. I would assume simiar load when belt pulling?
zx4ever
- Apr 14, 2011
I guess I do have custom airframe type running boards. But I’m sure you can hook it anywhere back there it’s a Yamaha it’s built tough and heavy. Lol
