RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
Well I was helping a friend with his primary clutch on his 2005 Rage when I noticed this in the case!! I'm not sure why it happened or what kind of material the case is made out of! Do you think JB WELD would hold up????
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
Well i see the case has an updated part number so I'm assuming they had problems with the original!!
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
I would try to JB Weld a small round piece of aluminum ( pop can ) over the hole such that the JB weld doesn't fall thru the hole. Not out much if it doesn't work.
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
I put JB weld on it! Didn't use any circle out pop can first though! It was pretty sticky when I applied it hopefully it doesn't run down and harden!
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
After looking I'm not sure that is a replaceable case at all! Might be part of the main engine housing. Having a hard time pegging it down on the parts fiche! Anyone know for sure??
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
I am by no means an engine guy. Maybe Hibshman25 can help.
This is the Case. Per the fiche it's:
CRANKCASE ASSY
8ES-15100-08-00 (replaces 8ES-W1510-00-00)
It looks like you could replace the case but wouldn't you be better off swapping out the engine? Or doing a permanent fix on the hole?
CRANKCASE ASSY
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
Yeah
Yeah the case isn't worth doing! If the JB weld doesn't hold the sled will get parted out!
CRANKCASE ASSY
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
A good welder could certainly tig weld that up. I see no reason JB weld would not hold.
Roger
- Feb 10, 2007
- Osgoode Ontario Canada
- 2012 RS Venture GT (power steering doesn't work when real cold)
2006 Indy 500
There doesn't appear to be any oil leaking out of it.
Probably a slight flaw in the casting.
Don't worry about it, especially since there isn't any oil there.
J1635
Suspended
- Aug 17, 2014
- Yamaha Nytro
Thats nothing for JB weld, just make sure you clean it really good as there will most likely be oil and dirt around there, i definitely wouldn't leave it, wouldnt want snow or water making its way inYeah
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Fine a rubber plug and the seal it with silicone and let it be. Betting the case is weak in that area
SNOTME
Pretty crazy if you ask me, I just bought an 05 Vector with the same hole in the same spot with the same shape. Did you ever find out what this is for or what may have caused it?
Thanks!
Thanks!
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
Never found out what caused it but it got JB welded up and is still running fine.
SNOTME
Nice, well now you are not alone. There are two of us! Thanks for getting back to me!
tcb4
- Mar 1, 2014
- Michigan, LP
- 2005 RS Rage, 2006 Nytro ER (Blown Motor)
Pretty sure it's factory, our 05 rage has the exact same hole in the exact same location. Curiously though, my 06 Nytro does not.
