Gibby
I see on their chart that for michigan elevation with the ECP kit you sould run red spring, i bought a used set up and it came with blue springs, will these work? what problems will it cause if i run blue instead of red? also i have a single undertunnel exhaust will this make a difference on what springs to run?
Thank you for the help
Gibby
Gibby
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Blues have a tendency to hang the slides open and you're stuck at wide open throttle then! I would probably recommend the silver springs for 99% of sea level riders with the ECP/KN Filter setup.
Gibby
can i buy these from you
Gibby
Gibby
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Gibby
thank you
RX1BANDIT
Try SLP's site.. They have them on close out for 25.00 plus shipping. dont know what they have left..
http://www.startinglineproducts.com/cat ... ductID=853
