Before I took my hood off from what I read it sounded like a pain. It was actually very simple. Also read that someone wished the harness was a inch longer but mine was very easy to get to. Who knows maybe I have some extra wire on mine lol or it might be the way I dissembled it.
Step 1. remove both side panels
Step 2.
Once the side covers are off their are two torx screw on each side right in this area that need to come out right in this area
Step 3.
Under the front bumper on the black plastic on the lowest part of nose you will see two more torx screws take them out. You will see a little blue on the tread that is lock tight. You will want to dab a bit on then when you reinstall.
Step 4.
Now that all the screws are off wiggle it forward a bit. Their is this black mesh insert just below the instrument cluster wiggle it and pull towards the rear and it will slide off.
Step 5.
Once the mesh is off you will see the harness clip towards the front and with that insert off their is plenty of room to stick your hand in and unplug it and the hood is ready to come off. Move it forwards and up for removal.
Step 2.
Step 3.
Step 4.
Step 5.
YamahaTim
- Sep 21, 2013
- Farmington, MN
- 2014 Yamaha Viper LTX SE MPI Turbo
Nice thanks.
NIce the potos help the guide in the manual is so small I have to use a magnifying glass. I am old you know - bad eyes
freelance
- Apr 15, 2013
- Manitoba, Canada
- 2014 Yamaha SR Viper XTX SE
Good job Apex.
Thanks for that.
Thanks for that.
hood removal
On your step three you say to remove two screws at lowest part of the nose on the black plastic, but I don't see those screws, can you give a pic of where these screws are and maybe and arrow showing the location would be really helpful? Have tried to find them but no luck, got the rear of the cover lose and can lift the cover up a couple inches and was able to unplug the harness but can't finish the removal without finding the front nose screws...HELP
Silkysmooth3popper
- Mar 19, 2013
They are way down on the bottom of the front of the hood below the front bumper. They go in from the bottom and point straight up.
canadianhunter
The 2 torx are just above the front part of the top A arm.
DeerHuntr
Sticky please
I will take some more detailed pics tomorrow and update the thread.
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
DeerHuntr said:Sticky please
It is. Here under bodywork
http://www.ty4stroke.com/viewtopic.php?t=120191
Kruzenkelvin
First 1000 miles!!
- Feb 21, 2015
- Sudbury Ontario
- 2014 SR Viper LTX , 2008 Phazer Gt
wish I read this a week ago when I took it off. Could not figure out how to reinstall, took way to long and I think I had about 20 screws out by the time I was done!! lol
I see some pics are now missing. Will get some on here asap. Sorry.
Pic showing locations
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
A nice add on that's on my summer wish list are these!!! http://www.evopowersports.com/Quick...archPage=1&searchRank=salesrank&searchSize=12
