apex4
need help:
i have had some issues with TPS, changed it all good except for ; cold idle is perfect idles down to required set point issue is:::: when its up to warm temps idles @ 1000/900 rpm....why to low for me...now i tried to adjust the idle screw on the iav (on top of engine) now this DOES NOT CHANGE IT WHEN OPERATING TEMPS) it only changes the cold idle.....where else can i change this except for the set screw for all for trottle bodies....
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
- www.yamaheater.com
- 2007 Attak - LOVE my sled!!!
You are adjusting the cold idle speed screw(fast idle), the Warm Idle screw on most I have seen looks like a screw you could turn with your fingers.
Usually has bumps around the outside edge, with a screwdriver adjustment in the center of it.
Make sure you have the right one, it is usually obvious when you look at it close.
There is a TPS adjustment, multiple syncing adjustments, and the cold idle adjustment, in addition to the Warm Idle adjustment.
I keep wanting a picture of the Warm Idle adjustment to send to guys when they ask, but don't have one yet.
Anyone out there have a good pic?
Hope this helps!
Rock
Hope this helps!
Rock
apex4
yes i do know what the idle screw is...black nobbie with standard (flat) screwdriver in the middle....thats what i have been tryin to change warm idle......seems to only change cold idle.......where is the other one???? as for tps adjustments....i adjusted this with D1 on gauge pod closed trottle 18...full trottle 99...which is right in the parameters per manual...
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
apex4 said:yes i do know what the idle screw is...
Dude, U gotta laugh!
Then why ask about it? lol
(Had to kid ya, was laughing when I read it.)
Seriously though, I get this question a bunch, is why I was asking if anyone has a pic of it.
It isn't so obvious to everyone, or they, like yourself, wouldn't ask.
A pic would be very helpful in this case.
Anyone have one?
new4stroker
Okay. We all have sleds 100 feet away. Someone who know grab their blackberry and post a pic. ( even an iCrap phone could do this). I am curious. I usually idle at 1500 last ride not less then 2500 at idle. Could not kick it down at all.
