swmpr1
- Nov 20, 2006
that's what mine does, sometimes cranks longer tho, did he hit the throttle to get it fired? if I do that, it will start but throws that code almost instantly. and mine a so-called 2015 model.
MCApex44
- Mar 30, 2006
- Western New York, Chautauqua County
- 2014 Viper RTX SE (sold)
x2...that is what mine does also. Not all the time but when it does its just like that.
BTW...was that the mbrp trail can in that video?
larrypolaris
Yes it was one of the MBRP can video's.
I noticed the hot start issues when I was revieweing the video's earlier this year.
My sled does the same thing once in a while. Hard to pin point it.
Just does it out of the clear blue. Like it gets a bug in it's butt.
Sure hope Yamaha comes up with a fix.
Oh, and I have the MBRP can. Sounds and works great on the sled.
MA03RX1ER
- Feb 12, 2007
- Georgetown, MA
- 2014 SR Viper XTX and 2003 RX1 w/MTN Conversion
dumb question, I know Stingray is using an actual gauge, but how are you other guys spouting off actual temperature numbers? All I've got on mine in C on one end and H on the other!
stingray719
Hold down lower left button on gauges and you can get numbers to appear, Matt from MPI told me after I installed an aftermarket gauge....lol.
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
- 2014 SR Viper LTX SE
2014 SR Viper LTX DX
2001 Venture 600
Given to a friend - 1998 SRX 700s
Other options are also available, instructions are in your owners manual!
Even shows max rpm. Handy!
stingray719
LOL, now you are going to make me look in my manual to see how to figure max rpms.
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
2001 Venture 600
Press and hold the upper button on the RPM side of the gage to activate maximum RPM feature.
Clears by turning off the ignition and restarting the engine!
Page 5 in the owners manual lower right side of the page!
The Operators manual can be found online at:
http://www.yamahamotorsports.com/assets/service/manuals/2014/LIT-12628-03-16_2165.pdf
stingray719
Thanks!
- Apr 14, 2003
- Hessel, Michigan
Bill, I thought you knew this feature..... Sorry, I should have showed you.
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
2001 Venture 600
I didn't know either so it was a good exercise for me to do the lookup and share with Bill and others.
stingray719
I guess I am too old school to read the manual....lol.
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
2001 Venture 600
T
The on line manual helps, I can open it on my phone, iPad, laptop, or desktop.
No need to carry paper around, also keeps the manual looking clean.
I know I'm older than you, but grew up with manuals (in or working with the military for 35+ years). Manuals are "Old School", you are actually new school! Actually making your own manual with your Modifications and sharing your findings!
Excalibour18
- Jul 21, 2014
- 2017 SideWinder L-TX SE Blue/White
I have not experienced this issue with the hot start yet, but I am sure that my air blows out away from the intake simply because when i stop to take a leak i put my gloves on the intake and they get super dried and warm lol.
My question tho lies with the ZR 7000 cat. that is the only cat that is using the same set up with different mapping in the ECU. Does the cat see the same issues? if not whats the difference between setups? It was brought up before with the ZR 5000 and also the 9000 series but they dont use the same engines, and the 9000 is turbo so i wouldnt expect the same issue there at all. I ride mostly in ontario flat trails and fields and like i say have not seen the issue yet. Is there any more information out there yet from yamaha as for a fix, and what does cat see on the 7000?
