ryan11007
- Feb 3, 2014
ok found my problems all good now. u can delete
sxvipersman
- Mar 19, 2006
- Dover Centre,ON Canada
- 2008 FX Nytro RTX Anniversary Edition
1979 Enticer 340
2009 FX Nytro XTX
Helped me get a shaft out of a viper
ryan11007
- Feb 3, 2014
thanks alot looks like i did it right. only issue is that when he hits the shaft out his comes out easy. i hit mine pretty hard with a brass hammer just wont go yet.This should help.
also chaincase stock bearing has no seals. then his new one has seals. should i not pop seals out and take grease out?
I would remove the frame member on secondary side. I removed the seals. Its same bearing both sides for drive shaft. Just no seal on chaincase side.thanks alot looks like i did it right. only issue is that when he hits the shaft out his comes out easy. i hit mine pretty hard with a brass hammer just wont go yet.
- 10K
