zackn291
Rider must of been light as f*ck. I weigh 145 and going across lake Nippising I got 145kmh. Maybe if I lost 9 pounds I would see 154kmh hmmmm?80h4thephaze said:Ive seen 154km'h completely stock.
80h4thephaze
LOL! 140 lbs will due the trick...
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
mine will click 90 or so, gut I can pull a clutched nytro to about 55 mph. with a clutch kit it should be better of the line. just do short races and you'll beat a lot of sleds twice the cc's
zackn291
is that what you weigh?80h4thephaze said:LOL! 140 lbs will due the trick...
woolyviper said:mine will click 90 or so, gut I can pull a clutched nytro to about 55 mph. with a clutch kit it should be better of the line. just do short races and you'll beat a lot of sleds twice the cc's
Thats why I dont whine too much about the lack of topend.This sled especially with the Freeride track and Ulmer clutch setup is unbelievably fast against others for a short distance.Will easily run with studded bigbore sleds for a good distance.It also helps coming out of corners and such.Also helps having that lowend for big whoops and drops to get front end up when you want it to.Railroad grades and the long stretches get real boring though!
A
Anonymous
lol
they do make a big hp phazer. it's called a fx nytro!!!!
yzf1999 said:Yeah I've had mine up to 94 on the speedometer.. but the real world speed is only in the mid to upper 80's.. The only time you really feel the sled is under powered is in deep snow.. I'm gonna order the Hauck (sp) git-er done kit soon for this season. I love my 07 fx.. if this sled was 120 hp it would be perfect.
soul_hammer
what clutch kits do you guys use? with the air pods and exhaust im thinking ill want one this year.
Ulmer
Prav
Schmidt Bros Primary kit + secondary overdrive kit (+5 mph on top w/o losing bottom end)
Haven't ran it yet though for results....
yzf1999
- Dec 25, 2006
- Bloomington, Illinois
- 2015 Yamaha SR Viper LTX SE
Ulmer primary and a Hauck secondary
soul_hammer
yzf1999
- Dec 25, 2006
The Ulmer primary by itself with 6 one inch air pods didnt really have an impact on the seat of the pants dyno. The Ulmer primary clutch did reduce engine breaking by about 10 percent, which was good. I like 4 stroke engine breaking, it helps in the twisties for better cornering, but the stock track would dance on high speed decelleration with the stock primary clutching. The Ulmer took care of that and still left plenty of engine breaking for the twisties.
I put the Hauck get-er done kit on this summer and it came with a new helix with a different spring position, so I haven't had a chance yet to evaluate it yet. Should kick #*$&@ !!!
soul_hammer
cool thanks for the info
- 8K
