Sled Dog
Wondering if anyone knows how long of a handle bar riser can I get without changing cables on a 04 RX1 Mountain?
I put a 2 inch on my womans 03 rx1 mountain. Bolts on but does not like turning. I just got the new cable yesterday so I will put it on this weekend. So I will say you need new cables at any change because the mountain has 6 inch bars from yamaha. That is unless you change the bars. Hope this helps.
P.s. I Am going to use a 05 cable for 2 inch risor. I will let you know after this weekend.
05 cables will allow you to put at least 2inch riser on. Might be able to get 4 inch on but might be tight. So to answer you question 1inch without changing cables but 2 inch they need to be changed. Hope this helps.
Sled Dog
I am 6' 1" tall so I need to raise the handle bars at least 6 inches. I have a 04 mountain sled I thought they came with longer cables but I guess not long enough for what I need.
Ratpack
I put 05 cables that I got from MPI and I have a 6" riser on. You have to take the clips off that hold the brake line and e-brake cable. I also made all off my wires 12" longer
yamahamaniac
I was told and it has been said here that the '05 rx-1 mountain cables are longer than the earlier years cables but I just finished asking the local dealer and he doesn't think they are longer at all but rather the same length. The powermadd throttle cable extension is another thought but it is too long for anything under 8 inches and it's a piece of crap. I had one on my '03 and it only lasted me about a year before it slowly frayed out and bust.
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
I have an 04 Mountain. I put 05 throttle cable with 2 inch riser block years ago with lots of slack. I switched to Apex Mountain bars with 8" Lake Effect riser (3 inch pivot with 5 inch riser = 8 inches rise) without a problem.
Just order the 05 mountain throttle cable.
yamahamaniac
Just finished installing the '05 cable on mine and it fit perfectly for approx. 6 inch rise with stock rx-1 mountain handle bars.
yamahamaniac
I wouldn't say that you can go any higher than 6 inches (with stock handle bars) with the '05 cable though, there will be too much strain on the cable.
Sled Dog
Thanks for all the help guys!
Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
I raised my bars 4" over stock (Lakeffect) and used Vector Mtn. cables to accomodate the added height; works great!
If you have a special custom project and can't find cables, there are shops that will custom make them:
http://www.greenskyadventures.com/throt ... custom.htm
http://www.motionpro.com/motorcycle/custom/
Send your existing cables to a shop and have them copied with the extra length you need.
