mrosenow
- Mar 23, 2008
- Neenah, WI
- www.harrisonstreetmotors.com
I have added a 2" riser to my XTX. Completely gets rid of the bars ripping out of your hands when you jump this sled. It really does need another inch or two to be perfectly balanced in the pivot point of the sled. Can I add a Nytro Mountan riser without extending my cables? Anyone know the magic number of inches we can go without mods?
Thanks.
Thanks.
BlueBlood
I added a Rox 3.5" to mine, no cable extensions required. I did do some re-routing, but it definitely works.
LeeKo
On the XTX anything over 2 inch riser and the cables need to be re-routed. I have a three and I would guess that BlueBlood is pretty much maxed and you couldn't go any longer.
Daranello
Suspended
Leeko ya happy with the 2" riser?LeeKo said:On the XTX anything over 2 inch riser and the cables need to be re-routed. I have a three and I would guess that BlueBlood is pretty much maxed and you couldn't go any longer.
LeeKo
I have the ROx Isovibe 2 inch and added the Rox 1 inch extension to get to a 3 inch rise. I am 6' 1" and was fine with the 2 inch but like the 3" better.
Daranello
Suspended
LeeKo said:I have the ROx Isovibe 2 inch and added the Rox 1 inch extension to get to a 3 inch rise. I am 6' 1" and was fine with the 2 inch but like the 3" better.
Is it good for trail riding also? and does the isovibe actually work?
LeeKo
I actually think the way mine is setup it is better than stock for trail riding because it relaxes the riding position. I think the sled has plenty of ski pressure and it is not necesary to be way forward.
You can set them how you like but mine is higher up than stock and slightly further back. I can now stand up and touch the handlebars without bending my knees.
It is hard to tell if the Isovibe really works but I am sure it doesn't hurt. I have them on 3 sleds and I like the idea. My other 2 sled have the Grip n rip Isovibe vs the Rox.
92vwgti
3 inch for me and im ok
