sethryder
went to put my secondary clutch back on after cleaning and noticed that the manual showed 4 shims on the secondary shaft (#4,#2 in manual). My jackshaft only had the two washers and one shim. My clutch is also able to slide in and out 1/16 on the jsckshaft. You guys only have one shim and some secondary float (back n forth movement) or am i missing shims? Thanks!
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
That sounds about right. What does the manual say?
sethryder
The manual shows a washer, 2 shims, then the secondary followed by two more shims and then a washer and bolt. My jackshaft had a washer, then the secondary, then one shim, one washer, and bolt. When mine is assembled u can see about 1/16" of the jackshaft spline exposed before the washer/bolt.
Snowmixer
- Oct 29, 2010
- Snohomish, Washington
- 2007 Phazer Mountain Lite
2008 Phazer MTX
2012 Arctic Cat M800 153
On my Phazer, there was one washer (of 'medium' thickness) that went on the jackshaft first, then the secondary goes on, then there was one very thin washer, one medium thickness washer, and one really thick washer, then the bolt that goes into the end of the jackshaft. If I remember correctly, the movement back and forth is actually called for in the manual, and the shims can be different from one sled to the next because they help get the secondary properly aligned to the primary. Look on pages 2-26 and 2-27 of the manual for more information about the free play and alignment, shims, etc.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
