Studroes144
- Oct 30, 2013
Well fortunately enough for me I have a real good warranty, I'm not pleased with this, but what really disturbs me is that I don't know if the reflash will make this better or if it'll still potentially be a problem
jim rice
- Oct 26, 2014
- Rx1
At this point I would be more worried about the value of the sled how much more money do you guys want to keep pouring into themWell fortunately enough for me I have a real good warranty, I'm not pleased with this, but what really disturbs me is that I don't know if the reflash will make this better or if it'll still potentially be a problem
Studroes144
- Oct 30, 2013
The money I've spent has been 100% for my personal preference, nothing else has influenced that at all. I'm surprised that there are so many that have had this problem, and unless I haven't been paying attention, I haven't seen much if any indication of this happening until within the last month. But seeming to be a lot more incidences coming out
jim rice
- Oct 26, 2014
- Rx1
Could it be the gems with all the added fuel causing a kick back on start just a thoughtThe money I've spent has been 100% for my personal preference, nothing else has influenced that at all. I'm surprised that there are so many that have had this problem, and unless I haven't been paying attention, I haven't seen much if any indication of this happening until within the last month. But seeming to be a lot more incidences coming out
Studroes144
- Oct 30, 2013
There's roughly 5-10 seconds on startup where the gems is not active, it's all stock fueling. With the afr gauge I can see the fueling on startup and it's usually 16-17. Is it possible that it's way too lean on startup? If anything I'd think you'd want it rich and then gradually lean out
Apex1958
- Feb 26, 2009
- Rotterdam, NY
- 06 Apex, 16 APEX LE
Sorry 144 I know it sucks. I had the re..flash done and my sled starts a lot quicker.jim rice
- Oct 26, 2014
- Rx1
I'm thinking too much fuel on shut off laying in the engine on the next start causing a misfireThere's roughly 5-10 seconds on startup where the gems is not active, it's all stock fueling. With the afr gauge I can see the fueling on startup and it's usually 16-17. Is it possible that it's way too lean on startup? If anything I'd think you'd want it rich and then gradually lean out
Studroes144
- Oct 30, 2013
My dealer is still waiting for the reflash stuff to come in. They got theirs awhile ago and it was defective and didn't work and haven't gotten a new one tet
Do the reflash. They want you to and I believe they have said it helps this. I also recommend my starting method. Grab the key dont wait for dash dont wait for fuel pump. Turn the key as fast as you can and dont let off till it starts.
Studroes144
- Oct 30, 2013
Maybe that's where I'm going wrong, last year that's the only way mine would start, if I cycled the pump it would start hard, now this year when I cycle the pump it starts good but I guess I should go back to the old technique
Kerrdog569
- Sep 11, 2014
- East jordan,michigan
- 2017 Yamaha sidewinder xtx se
It's happened on a bunch of stock sledsI'm thinking too much fuel on shut off laying in the engine on the next start causing a misfire
Kerrdog569
- Sep 11, 2014
I've been starting my viper this way ever since I read your post and mine starts perfect every time hot or cold,thanks for the heads upDo the reflash. They want you to and I believe they have said it helps this. I also recommend my starting method. Grab the key dont wait for dash dont wait for fuel pump. Turn the key as fast as you can and dont let off till it starts.
tator
mine backfired once. it was after i did some clutching and rotated the motor by hand. not sure if it has anything to do with it. but with 2700 miles on it, that was the only time.
It's worked for others also. Have had hard starters even after re flash and they have been amazed when it fired right up using this method. Now I learned way back in auto class to never tell a customer how to start their vehicle. Always find something wrong to keep it impersonable. But in this case it seems it's necessary.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
I am not reflashed yet but last season i had terrible hot start issues.
This year i am turning the key to start immediatly, no delay, and it starts pretty dam good now.
I was going to wait out the season to see how the reflash works out for everyone.
